Having trouble refueling , hose keeps shutting off
Good idea above. Another common cause for this symptom is a problematic evap system. If above idea isn’t effective, expect that as the next most likely. As fuel enters the tank from the pump the air in the tank has to have someplace to go, otherwise pressure builds up and shuts off pump. The air (and fumes) is supposed be routed to the canister, where the fumes are captured, and the air expelled via a vent valve. So you could have something wrong with all that. Most likely would be the vent valve isn’t opening upon computer command like it should, or is plugged w/gunk.
