Dexron-VI ATF is specified in the owner’s manuals for 2018+ Enclaves, which use the 9T65 transmission. There is a Dexron-HP (High Performance) fluid, used in situations where low temperature fluidity and potential fuel economy are priorities (according to GM–note this may apply to both VI and HP), and that was first used in 2018 in the 9T50 transmission (according to Wikipedia). Perhaps this is the “new” fluid that has been mentioned above. It is supposedly backward compatible with Dexron-VI (but don’t take my word on that). Just doing a drain and fill with the new HP fluid may not get enough of the new fluid in the trans to be an advantage. A full exchange would be required.
Bugmenot
21
| Non-Serviceable Transmission (GM) | 34 | 15839 | December 20, 2014 | |
| Can I drain transmission fluid and replace withexact amount? | 39 | 5237 | April 23, 2023 | |
| Too much transmission fluid in Buick Lesabre 2003? | 34 | 36257 | July 27, 2018 | |
| The Great Debate | 28 | 2370 | November 4, 2015 | |
| Transmission fluid flush vs drain and replace fluid | 79 | 59022 | October 24, 2024 |
