2017 Ford Edge - Shakes
ford edge 2017 engine in d shakes and shuts down
With the little info you gave. my crystal ball says this…
Ford recalls vehicles with defective torque converters | MotorSafety.org
With more info it might get you more accurate answers to the problem.
Could also be an engine misfire problem. Hope for that, torque converter repair is probably much more expensive. Generally those symptoms would turn on the check engine light. Is it on? Also suggest ask your shop to use their scan tool to read the active and pending diagnostic codes stored in computer memory, and post the numbers here. the numbers usually begin with the letter “P” (for powertrain); e.g. p0300 is for misfires. Google that number, will explain more about it.
thanks George for the information, the iginer check does not turn on
