2017 Dodge Grand Caravan Rough idle and vibration
engine idle rough accelerating engine vibrates likecrazy and engine lite is on now interior lites are staying onengine vibration not consistant
I suggest you bring it to your local Autoparts store and have the engine codes read. they will do it for free and then you can post the codes back here. someone here may be able to help you better. especially if you add some spaces and periods to your sentences. :wink:
there have been complaints for a cylinder #2 misfire on your vehicle which led to having the head replaced in a lot of the cases.
Don’t simply ignore a misfire symptom like this. The engine’s catalytic converter could be damaged & require an expensive repair, damaged in a matter of weeks when driving w/a misfire.
