2016 vw jetta lurching forward when idling, rpm jump
A few weeks ago while idling in traffic my car starts lurching forward on it’s own, RPMs jumping considerably while my foot is all the way on the brake. The car didn’t legitimately move forward, but was trying to, and would’ve if I wasn’t already braking. Pretty freaky thing to have happen when you’re in bumper to bumper traffic. I took it in to a vw dealership thinking it was a vacuum leak, they checked it out thoroughly, drove it a bunch, hooked it up to the computer, looked for error codes, the whole shebang. They said everything was fine and they didn’t know what could’ve caused it. I took my car home, but I swear it’s not quite right, acceleration feels weird, sometimes feels too slow to get going or too fast to get going, touchy in general.
Come today, I’m on my way to work, idling at a red light and the lurching thing happens again, only this time the RPM spike is little more drastic. It literally felt like my car was going to accelerate through the brake? Cue throwing the car into park and turning on my hazards in an inconvenient spot. Lurching still happens in park, I shut my engine off, give it about a minute, turn it back on, goes right to essentially accelerating on its own again. Turned it off again, waited 30 minutes or so in hopes cooling down would help, it does, and I was able to start it up and get it home. Again it didn’t feel normal, gas still either felt too touchy or laggy and I don’t dare drive on this problem in traffic.
Anyone got any ideas?
Your car is probably beyond carmaker’s warranty - but if the VW dealer has been unable to figure this out, I would contact VW corporate. See owners manual for how to. There may be a TSB or a regional tech person who can address this. Yes, the dealer should be doing this, but what can you do? Do what you can do.
Thank you, I’ll check this route out!
I’d also post this on VW forums (VWVortex, TheSamba) and see if anyone there has had this problem.
Will do, thank you
You wrote: “lurching still happens in park”. I hope you are saying that when you are in park, the engine surges. Or, is the car still trying to move forward?
Yeah, what I meant was while in park the engine still surges
Try a different local mechanic. There may be deposits on the throttle body that cause the throttle plate to stick and jerk. There may an ICM Idle Control Motor that needs attention.
That would also be my prime suspect.
My Son’s 2016 Jetta, 1.8L L4 CPKA TFSI DI 170HP was exeriencing the same problem. No codes were generated. However, I suspected a clogged or failing PCV valve as the cause. I installed a VW PCV Emissions Service Kit - CRP KIT-00631, purchased from FCP Euro. The car functioned normally for about 1200 miles, then, the problem returned. I have just replaced the MAP Sensor and will to try cleaning or replacing the MAF sensor.
Update. The previously described problem with my 2016 Jetta, (erratic idle, lurching and stalling) continued. I finally found a VW expert who properly discovered the cause and replaced the timing chain and front crank seal. At or near 80k miles, the timing chain / belt goes bad and causes these issues described. The timimg only needs to be slightly out for the issues to present themselves. Left uncorrected, it could result in engine rebuild or replacement. Total repair cost for timing chain replacement was $1265. and well worth it. The average repair costs depend on your location, labor, etc and may differ from my repair cost.
But, the problem has been solved.
Thank you for the update…
Jetta has 1.4 and 1.8 motor. Do both have timing issues as described? I might assume that the diesel version is not being discussed?
Both, 1.4 and 1.8 experience timinig issues, whether timing belt, or timing chain. The main culpret is the poorky engineered timing belt / chain tension actuator. Over time, approximately 80K miles, it fails in the retracted position and allows the Belt / chain to slip and stretch. The timing changes and results in a host of issues.
