2016 Toyota Aqua tire issue
3 of my tires are cutting on the inside and outside, is this a problem with the tire pressure? I recently had it aligned. It"s a Toyota Aqua hybrid. This model is not on your list.
Yes, if by “cutting” you mean the tires are wearing on inside and outside edges and not in the middle. Classic, under-inflation wear.
Please tell us if you keep your tires at the proper pressure or not.
Same car as the Prius C offered here.
If you mean cupping, that usually happens on therear of lightly loaded front drive vehicles. Not rotating tires or needing shocks or strurs can make it worse. If you mean cutting. I don’t know what you are talking about.
