Overheated head cylinder
And??? Why did you not turn off your engine when the temperature gauge went up? Now, what do you plan to do?
Are you perhaps referring to a warped cylinder head? If so, you need the services of a good mechanic.
Which one? You have 2.
Did you drive the vehicle until the engine seized up . . . ?!
If so, you need a new and/or remanufactured engine
