AC won’t blow cool, small crack on the front diffuser.
You are going to have to start checking out what is working and what is not working, you could have a perfectly working AC with a blend door stuck in the hot position, or an electrical issue, or a leak in the AC system somewhere, or the HVAC head unit or module bad or in need of software update, or many other things… You have to hook up to a set of manifold gauges to check for correct pressure and to see if the compressor is working or not… Since you cracked your front diffuser by hitting something, you could have also put a hole in the AC condenser… and I am missing 100 other things it could be… lol
Lots of different possibility’s, just find a good shop and let them do a proper diag to see why it is not working…
