2016 Dodge Dart - No clutch won't shift
Clutch goes to the floor and won’t come back up. Won’t shift
The clutch is broken. Either the master cylinder, or slave cylinder or the line has broken or the pressure plate spring has broken.
And if it turns out to be the master or slave cylinder, replace whichever one it isn’t as well, because it’s probably not far behind.
