clear coat scratches easily?
Not sure what your are asking. Clearcoat is basically a clear paint in simple terms not some really tough coating . Did you scratch it or is it damaged ?
Do you regularly use the same automatic car wash? Maybe you should seek out one better maintained. The brush-type washes can get debris stuck in the foam brushed and scratch the heck out of your paint. Those scratches most likely can be buffed out at a car detail shop.
