2015 Nissan Versa - Headlights burn out
Head lights keep burning out monthly.
A few reasons I can think of that might cause this are…
touching bulb glass with your fingers. the oil from your skin can affect bulb life.
moister inside the lens
a cut or corroded wire
the connector that connects to the bulb can be burnt or melted causing a short.
a defective alternator that is over charging.
wrong type of bulb installed
Ask your shop to do their standard battery/alternator test. A diy’er version can be done with a volt-meter:
  • measure the battery voltage before first start of the day. Should be about 12.6 volts
  • then, after starting the engine, 13.5 - 15.5 volts.
If that test passes, WW’s ideas are good ones to consider. It’s also possible you are getting faulty replacement bulbs. I’ve had that happen to me. Sometimes a parts store will get an entire shipment of bad bulbs. One idea, buy the next bulb from a different parts store.
As the others have mentioned, if the bulbs are truly burning out then the charging system has a problem, and the alternator may need to be replaced. If the bulbs are just not working, then there is a power connection problem that needs to be addressed. I also suggest you try to get bulbs made by Phillips for longer bulb life.
