This is very aggravating. I jiggle the light and it works, but after driving off in just a few feet, it no longer works. The bulb is still good, but the connection is loose. This is dangerous and I do not know what to do to correct this situation.
Dan Ross wilsonville or
Well , Dan neither do I . Because you did not say what light you are having trouble with . But if you show it to a good shop they can solve this for you.
If the connector is loose you should replace it. If it is for a headlamp you may be able to buy one at a local parts store. If it is for a different lamp you will need to order the pigtail from a dealer.
