Have a 2015 Kia Sedona with 22000 miles. Will not crank, battery is good looks like the starter. Anyone else with this problem?
There have been many very recent threads dealing with the exact problem with many very good recommendation. Rather than regurgitating what was already covered, please try to search this forum. This problem is not unique to your Kia.
How do you know battery “is good”?
Assuming the battery has been tested and it’s okay, on some older Hyundais/Kias there’s a relay gizmo under the dash called an Intelligent Power Switch module. If it goes bad the result can be failure to crank. Dunno if your vehicle even has one but it might be something to check.
Thanks, I tested the battery, starter and checked all fuses and relays. Tried to start it in park and neutral. Having it towed to the dealer today. The warranty expired 2 months ago, but with only 22,000 highway miles I’m hoping they will still pay for repairs. Thanks for your help.
You can always hope but probably not. Warranties are in terms of XX months or XX,000 miles, whichever comes first.
