2015 Jeep Wrangler Unlimited - constant ticking
constant ticking on the passenger side of the motor. It does it idling and driving
Start by checking your oil. How often do you check it? How often do you change it? If it’s low, add oil. How many miles on your Jeep?
The oil is changed whenever the jeep notification comes on. I did check the oil and it is fine. There is approximately 46,000 miles on the jeep.
Charlene
Probably will not be a big problem but it is not a good thing to put all this personal contact info on an open web site . @cdaquila Carolyn , edit time again ?
