Car frequently won’t start after not being used several days. Have you had a similar problem?
I own a Corolla, never have experienced that problem myself. I expect your Camry has something wrong with it. When you say it “won’t start”, do you mean it doesn’t crank, that rrr rrr rrr sound you normally hear with the key in “start”? Or does it still crank ok, but won’t catch and run?
Will it jump start OK???
If so then check your battery, if bad replace it, if it checks out ok, check for a parasitic draw…
