2014 Nissan Pathfinder - No rear heat
2014 nissan pathfinder sv rear console is little to no air coming out in the center console.Even if I turn to full position of the switch.
Whenever air flow is less than perfect but flowing more than zero I always suspect a filter is in need of replacement. I’d start by removing the cabin air filter entirely, then running the air to see if that helps. If it does help, the filter needed to be changed. If it’s gross, change it anyway. Normally, it is located behind the glove box and the parts are under $20 at Amazon.
The rear blower motor may have failed, or the fuse may have blown.
Are there blend doors involved? If so, I’d suspect one of being stuck.
