no dash lights, tried to program the fob and nothing does not comunicate w the computer
ASs far as the dash lights, first check the dashboard dimmer switch to see if it was turned off. if not check for a bad fuse or relay.
as far as the key fob… if you have not already… change the fob battery
I hope you’re not selling this car. No one will want it with no dash lights and a messed up fob.
Maybe a bad body control computer.
The key fob communicates with the BCM.
What in the world are you trying to say ?
Houston we have a problem, non-sense about an unknown module. Is there someone else out here with us?
David-John makes a lot of posts that are mostly Gibberish . English may not be his primary language .
