abs light on after mecanic change bearing could it be the cause
without knowing what code the ABS light is throwing it’s impossible to know for sure.
Hi the code on the scanner
Open circuit no signal
And the mecanic told me because the bearing was almost falling
It broke the sensor!
I think its bunch of bs
Depending on the particular design . . . a bad wheel bearing can most certainly damage a wheel speed sensor
But I would first check if the sensor is even plugged in . . .
In my old 05 Town & Country I had a wheel bearing that almost shattered and it took the sensor out with it…definitely not BS
