Automatic window, climate control, radio tuner and radio volume all stop working sometimes. Usually happens when it is cold but not always. Returns to normal after a few minutes to a day
I am not familiar with your vehicle but, How old is your battery? it might need to be replaced. if it is weak it can cause problems. you have these problems when you first start your vehicle, the alternator charges the battery while you are driving and then everything starts working again.
There may be an issue with the BCM.
I’d test the 12V battery, if it tests good then look into the BCM.
