2013 Toyota Avalon - Seat heater issues
how to fix seat heater in 2013 avalon
1st you need to know what is wrong with it, switch bad, wiring bad, heater bad, etc??
Fixing the seat heater in your 2013 Toyota Avalon can involve a few steps. Here are some general troubleshooting tips:
  1. Check the Fuse: The first step is to check the fuse related to the seat heater. The fuse box is usually located under the dashboard or in the engine compartment. Refer to your owner’s manual for the exact location and fuse specifications.
  2. Inspect the Wiring: Look for any visible damage or loose connections in the wiring under the seat. Sometimes, the wires can get disconnected or damaged over time.
  3. Test the Seat Heater Switch: The switch that controls the seat heater might be faulty. You can test it using a multimeter to ensure it’s working correctly.
  4. Check the Heating Element: If the fuse and wiring are fine, the issue might be with the heating element itself. This can be more complex to fix and might require removing the seat cover to access the heating pads.
how to fix HEATED SEATS PROBLEM TOYOTA with WIRING DIAGRAM (youtube.com)
