climate control selection does not change where air flow is directed. I select feet and it blows out in all 3 locations, same with any other selection, it always blows in all 3 locations, even on max air cond.
It is likely that either the mode door actuator has failed, the mode door itself is stuck, or the mode selector on the control panel has failed.
