Radio and amplifier not work, no sound
you should check fuses and relays to see if they are bad. also if the radio comes on but you have no sound it is possible that you need a new amplifier. if there is no power to the radio and amp. then it is a fuse, relay or bad wire.
I’ll give my usual advice, which is take it to a car audio shop.
