2013 Chevrolet Equinox - Leaks
car serching leaking oil from the engine on the right wheel
No experience w/your vehicle but if transverse engine orientation, an oil leak spotted there could be from front crankshaft seal or camshaft seal(s). Valve cover seals common oil leak source as well. Some good news, all 3 seals usually possible to replace w/out removing engine. Faulty oil pan gasket could also cause a leak in that area. Be sure to check the engine oil level daily before starting engine until this is resolved.
Let me get this right. Oh never mind. Any chance you to actually string some words together that form a coherent question? On the tire I’m going with either leaking caliper, brake line or neighbors dog and it ain’t “oil”.
