2013 Acura ILX - Vibrates
vibrating when deaccelerating after accelerating to speeds 60 to 70 mph
Likely a bad hydraulic engine mount.
Are you using the brakes at the time? If so, it could be a warped rotor.
Not when braking, vibration occurs when accelerating to 55-70mph and letting off , if you shift to neutral the vibration goes away
This email (and any attachment) is intended solely for the addressee and may contain confidential information. If you have received this email in error, please notify us immediately and delete it. Reading, disclosing, copying or disseminating any portion of this transmission without authorization is prohibited. For more information on our range of services, please visit
Could also be something between the transmission and the wheels. Does this vehicle have AWD?
That was my thought too, especially since the vibration goes away in neutral. Maybe a bad CV joint?
