rough gear change also take a while to change gear.
thank you
Your Welcome .
how many miles are on your car? have you ever had the fluid and filter changed? are there any spots on the floor under where you park your car?
have you looked under your car for any tranny fluid leakage?
also does your car have a tranny dipstick to check fluid level? if so check the level.
like weekend warrior said, most automatic transmission issues are associated with fluid level issues or the fact that the transmission fluid needs to be flushed.
