2012 Nissan Murano - P0746 and P0455
P0746 and p0455 Cleaned maf sensor and thought might need a new one and was told it may be evap vent valve canister/solenoid/tube related. Wondering if anyone has had any similar issues
https://www.transmissionrepaircostguide.com/p0746/
You’ve got 2 separate fault codes, one that tells you there may be a fuel vapor leak and one that tells you there may be a problem internal to the transmission. Why on earth would you be looking at the Mass Air Flow sensor which has nothing to do with either one of those?
