2012 Jeep Liberty - Lighting Issues
I have a 2012 Jeep liberty and the front left running lights will not work. The directional works. Also the rear right running light is out but the bulb is ok. I changed all the bulbs, the front running light socket, and the relay in the power box. HELP
Have you checked your fuses?
according to YOUR owners manual
The under hood fuse box
Fuse M18 is a Blue 15 Amp fuse, it is for Exterior Lighting – Passenger side of car
Right Front Park and
Side Marker, Right
Tail and Running
Lights
Fuse M17 is a Blue 15 Amp fuse, it is for Exterior Lighting – Drivers side of car
Left Front Park and
Side Marker, Left Tail
and Running, License
Lights
Starting on page 492
The fuses are ok. I put a new socket on the running light and a new relay in the fusebox ?
