2012 civic with 136,000 kms
is this time for transmission fluid drain and replace fluids?
Yes, that’s close to 85000 miles, it’s time
That answer is in the owners manual(s.) It will have a time factor and a distance driven factor.
The owners manual usually says something on the order of " transmission fluid does not need to be changed in normal service". You know that most of us here call BS on that if you keep your car for a long time. In this case, the answer is NOT in the owners manual.
