2012 Chrysler 300 Powertrain Noise
Mildly aggressive brakes use often results producing a ‘clunk’ sound upon end of vehicle stop (termination).
Worn sway bar bushing/end links, ball joints. name it?
Take it in to get checked out.
Thanks for providing a logical possibility. I’ll be informing the vehicle owner soon. :+1:
Too much play in some part of the driveline can cause this too. First step, ask shop to visually check driveline path from the transmission to the drive- wheels. Brake system problem should be considered a possibility too, but seems less likely than the suspension or driveline theories.
If I ventured to make a guess, problematic strut or ball-joint.
