6 speed manual .i have a break fluid leak in clutch somewhere, had hose reconnected and no longer leaking at hoseline. linto slave cylinder leaking somewhere else?not sure if slave is good or something else disconnected.
trying to fill and bleed, no pressure in clutch
What is your question? Clutch hydraulics are pretty simple. One master, one slave, one hose one hard line. Replace them all if you have any doubts.
But make sure the clutch fork is properly positioned and that the pressure plate hasn’t failed.
