I recently had a stroke and as a result was not using my car and had to have a friend charge up the battery. When it was moved from work to home about 5 months ago, I noticed that none of the lights were working in the back. That includes the break lights, the lights that stay on, and possibly the blinker light. Luckily the break light in the spoiler still worked. Got any suggestions on what has happened?
The bulbs may have been burned out for quite some time. After all, you can’t see it when you are driving. Change the bulbs. If that doesn’t work, look for bad ground connections in the trunk.
Sorry about your stroke, hope you are doing better.
