2011 Mercedes-Benz E-Class has inside rear tire wear
Tire wear on inside rear
You probably need a wheel alignment. A good shop can tell you if there’s something more serious. Does your E Class have air suspension?
Yep, likely normal unless you need an alignment. Rotate your tires more often.
Same wear on both? Extreme or mild? Tires nearly worn out otherwise?
