I get p0011 code, some times my engine start reving up and slowing down with out a reason when i stop, even stalls i check camshaft position sensor and variable valve thay are fine, any idea what could be wrong?
What’s ths mileage on the car?
Was oil regularly replaced?
Any sludging problems?
I replace synthetic oil regularly, no sludging problem 87000 miles
You might entertain the idea of valve control solenoid failure.
The valve works i checked it by taking it out and applying voltage to it
I also have done this, and have the same random revving up and stalling WHENEVER with my 2012 gold 2.5! Please update me if you do anything and it stops and I’ll do the same, gotta help each other out lol.
