It make noise on the engine when put it gear and the engine is cold.
Could you describe the noise? or could you make a recording, upload it to YouTube, then link it here?
the noise is like Bruuuuu
Could be a small leak in the exhaust that closes up as things heat up. Try to locate it quickly right after starting a cold engine.
The noise is on the engine
Ask someone to plug the tailpipe with a rag while you look under the car for the leak.There will be a definite change in tone of the exhaust system.Do this on a cold engine.
someone eng neath told me about the mountain underneath the engine
Ummm… I am almost speechless.
mounting - engine mounts
Yes, a dope slap for me, for not understanding that… word.
