Hey
Issue: On the passenger side, only cold air is blowing when the heater is blasted.
I’ve already changed the blend door actuator. Replaced it incorrectly the first time so got a bit familiar with it. Had cold air blasted on me and had to mess with the alignment of it. Luckily no damage, installed it again appropriately and the heater was working again on the driver side. But even with a new actuator, the passenger side still only gets cold air. Different levels of cold air but still, cold air.
So this question came to mind. Are there two blend door actuators? One for each side? If not, any other recommendations for what can fix the cold air on the passenger side when blasting the heater?
Also for the people who need to actually replace the actuator on a Venza, it’s on the driver side. Once you know what it looks like, it’s pretty visible through the open space below. Not the same location as the linked video, it’s further up and more in the center between the brake and gas pedal.
