2010 honda cr-v exl
4 DOOR WAGON/SPORT UTILITY
2.4L I4 F DOHC 16V
FRONT WHEEL DRIVE
177,000
No accidents
Two owners
Maintenance seems to be current - what major repairs can I expect to have pop up between now and 200,000 miles? Showing what was done below - it seems like my Son can get a lot of use and safety out of this but wondering if I am missing something ‘big’ that is normal to wear out/require replacement. First time buying a car on my own so any guidance from someone more experienced would be helpful.
They just did the following this month so that looked good.
  • Vehicle serviced
  • Brake light bulb(s) replaced
  • Oil and filter changed
  • Four tires balanced
  • Four tires mounted
  • Four wheel alignment performed
  • Air filter replaced
  • Cabin air filter replaced/cleaned
  • Wiper(s) replaced
  • A/C refrigerant recharged
  • Anti-theft/keyless device/alarm installed
Back in 10/2017 the following was done:
  • Vehicle serviced
  • Maintenance inspection completed
  • Throttle body cleaned/serviced
  • Tire(s) balanced
  • Tires rotated
  • Steering/suspension checked
  • Alignment checked
  • Transmission serviced
  • Body electrical system checked
  • Windshield washer checked
  • Safety inspection performed
  • Alignment performed
  • Antifreeze/coolant flushed/changed
June 2016 following
  • Vehicle serviced
  • Spark plug(s) replaced
  • Left airbag assembly replaced
  • Antifreeze/coolant checked
  • Brake fluid flushed/changed
  • Rear brake pads replaced
  • Brake rotor(s) resurfaced
  • Front brakes replaced
  • Power steering checked
  • Emissions inspection performed
  • Emissions or safety inspection performed
Reads good and shouldn’t need anything but oil changes in the next 23,000 miles but…
I can’t see, hear, smell or drive it from here. Pay your mechanic inspect the car before you buy it. Best $100 or so you will ever spend.
After market device would be the only red flag that I see as it could cause problem’s later down the road.
If you buy it after the pre-purchase inspection, get a 4 wheel alignment done immediately. It looks like the current owner bought new tires, but did not get an alignment done. Other possibilities are new suspension parts and brake calipers, and your pre-purchase inspection will suss that out.
Edit: missed the alignment. Oops! Thanks for pointing that out, @shanonia.
4 wheel alignment was just done
I’d be curious to know what maintenance was done between 10/17 and this month. That’s a fair size gap. Beyond that, let a mechanic of your choice inspect it.
Owner 2
Purchased: 2014
Personal Vehicle
16,043 mi/yr
05/01/2014
78,047
  • Odometer reading reported
  • Title or registration issued
  • New owner reported
04/27/2015
96,064
  • Vehicle serviced
  • A/C relay replaced
  • A/C and heating system checked
05/14/2015
96,938
  • Vehicle serviced
06/03/2016
117,367
  • Vehicle serviced
08/31/2016
124,556
  • Vehicle serviced
  • Drive belts checked
  • Alignment checked
  • Tire(s) replaced
09/19/2016
125,520
  • Vehicle serviced
  • Tire(s) balanced
  • Tires rotated
12/16/2016
130,528
  • Vehicle serviced
  • Tires rotated
04/21/2017
138,917
  • Vehicle serviced
  • Tires rotated
  • Tire condition and pressure checked
10/11/2017
143,828
  • Vehicle serviced
  • Tire(s) balanced
  • Tires rotated
  • Alignment checked
04/03/2018
147,215
  • Vehicle serviced
12/11/2018
152,302
  • Vehicle serviced
05/07/2019
157,837
  • Vehicle serviced
  • Emissions system serviced
  • Air filter checked
09/03/2019
163,849
  • Vehicle serviced
03/13/2020
170,977
  • Vehicle serviced
05/05/2020
173,533
  • Vehicle serviced
177,343
07/11/2020
  • Vehicle serviced
  • Wiper(s) replaced
That was on me, sorry I didn’t post the entire history, just added that below. Thanks!
All looks prtetty good except the ac recharge, there may be a leak somewhere that will pop up again. I would ask if they put dye in for the ac recharge, if so take it to an independant mechanic to see if a leak can be found, and also do a complete inspection to let you know about brakes tires and suspension components.
No worries. The missing chunk of maintenance history just scared me a little. Looks good.
Except for valve lash which which should be checked on a regular basis so you won’t have to face this annoying and expensive problem IF that has not been done… True of any engine with mechanical lifters.
Otherwise, the records look surprisingly good as most records are non-existent.
I agree with the comment on the AC as it is a known weak point for this gen CRV’s. But then again, with that many miles on the car, if you are getting a good deal, you might as well roll the window and enjoy the fresh air :slight_smile:
Have the mechanic do a leak test but I think the compressor is the one that goes.
