After I get my engine oil changed it smells as if they spilled oil on the exhaust for weeks after. I changed the pcv valve and hose,steamed cleaned engine. I even changed the oil myself thinking they put wrong oil in still smells. It is not the ptu know that smell had that problem.
Did you check your valve cover gasket for oil leak?
