drive window not work
Bad fuse, wiring, window switch or motor. Take your pick.
This can be caused by a broken wire inside the conduit between the door and the body
Since the drivers door is used the most. that’s the door to most likely to have the problem
One way to find out is, turn the ignition on.
Hold the window switch in the position you want the window to go, While slowly opening and closing the door.
If at any point the window moves, that’s the problem.
