Camshaft position sensor code p0341 is showing up. I have replaced the sensor and checked for continuity from the wiring harness, and everything seems ok. The code is still showing up and the care has a heavy oil leak from the left side of engine.
Worn out timing chain and guides can cause this. An oil leak can’t cause this error but should be fixed.
