Believe the passenger side wheel bearing needs replaced.
And what leads you to this conclusion? Noise? Vibration? Similar symptoms can be caused by a bad cv joint.
Roaring noise. No vibration.
Assuming the tires are in good condition you’re probably right.
Yeah the tires are new.
Ok , if you are correct and this is not something you can replace your self then have it looked at before the silly wheel falls off.
