2008 Toyota Prius - Vibrations above 60
At speeds of 60 and higher the engine develops a bad vibration. No codes. What causes this
Are you sure it’s the engine ?
Sounds more like a tire balance or bent wheel problem based on the speed it happens
And if not either of those, maybe a worn suspension part.
