Does brake fluid need to be flushed regularly or at all?
follow the maintenance schedule listed in your owners manual.
YES! Brake fluid is the most ignored fluid in the car.
Have it flushed at every brake job or at least every 5 years (better every 3 if in a humid region) if the car sits around a lot. You will avoid a lot of common brake problems as the car ages if you flush brake fluid regularly.
Thank you!
