2008 Saturn Aura Brake pedal goes to the floor before brakes are engaged
I have replaced the front rotors, calibers, pads and brake lines. I went through the process of bleeding the brakes by using the following sequence: right rear, left rear, right front and left front.
I did this about 4 times - process was to pump the break until the pedal was hard then my son kept his foot on the pedal while I release the bleeder value. During this process I kept the master cylinder full.
Took the car out and the pedal went right to the floor when applying the brakes. The car did stop but not as I had expected.
So what have I done incorrectly here? Is there something else to check?
Did you allow the brake master cylinder to run empty when replacing the calipers/brake lines?
Try turning the ignition ON then OFF to cycle the ABS. Then bleed again.
That is a classic symptom of a bad master cylinder. You might need a new one.
