My wife’s car. 6000 miles. What maintenance is required? Oil change interval? Radiator fluid? Etc.?
That info will be found in your owners manual and how does a 2008 only have 6000 miles.
If this is a 2008, and only has 6k miles, nearly every fluid in the car needs changing starting with the brake fluid. Oil changes every year regardless of miles driven, 5 years max on coolant, 3 years max on brake fluid. Transmission fluid and differential fluid are the only ones I’d ignore.
