2008 Ford F-150 - Lights out
2008 f150 my tail lights is not working,any suggestions
Check fuse 6 in the fuse box
Check the bulbs… lol
Had a mechanic onetime that was convinced that a car needed a brake light switch all because all the brake lights were out (not working), I asked if he checked the bulbs and he said no, I said check the bulbs and get back to me… it had blown overtime all the bulbs… lol
But check fuses as already said…
Check for a ground connection in each bulb socket. I’ll bet you don’t have one if ALL the lights are out. Find and fix the ground. If you have ground, check for voltage.
Good grief . . .
Remove the taillights . . . it should take but a few minutes . . . and inspect the bulbs
If they’re black(ened) or have broken filaments, replace them
