2007 Toyota Tundra 2WD Truck - Trans slips
transmission is slipping and holding longing long shifts in low gears
When was the last time the transmission fluid was serviced?
I suspect transmission service will not help this late in the game. But you could try it.
Does it slip all the time, or only when you’re going slow? What happens if you switch overdrive off?
