2007 Subaru Legacy - Filter stuck
Changed oil in motor, but unable to remove filter, done up too tight, wondering if ok to refill with fresh oil, only problem is i used a engine flush, so there will be some of that in filter, will this affect the motor will I get to someone who can get the filter off? Thanks
Get one of these. It should be able to get your filter off. You NEED to get your filter off I’M HOME.
