In my power steering reservoir my oil power steering it is Muddy beige color power steering is hard to turn
I assume the engine is the V6. Use a turkey baster or similar to remove as much fluid from the reservoir as possible and replace with fresh ps fluid. Drive a bit to circulate the fresh fluid through the system. Repeat a few times until the fluid is clean, hopefully damage has not already occurred.
Ed B.
