2007 Hyundai Santa Fe - Airbag light
Aibag light comes on the at engine start goes out for max 2 seconds and then stays on
Requires shop diagnosis with a pro-level scanner.
Is for the passenger side? If it is, there is a sensor in the seat bottom that can be bad or have a broker wire. it seems to be a common problem.
If not give the dealer a call. they will know if there is a service bulletin for this problem. There is always a chance it could be covered under the air bag recall.
