2007 Honda Element - AC
When I turn the ventilation control dial to Defrost, the AC comes on and defogs the window nicely. But when I return it to normal ventilation the AC remains on, even with the temp control turned up.
There appears to be a switch at the bottom of the temperature selector that allows you to select A/C on or off, is that switch not working?
